control nesting bug involving square off fall
Thomas strembitsky
Postby Thomas strembitsky » Fri, Nov 10 2017, 12:37PM
in control nesting load a job with a few pieces on the sheet that will leave a big off fall then nest the job. then go to edit ----> nesting parameters and check off make off fall square. doesn't do anything even if you nest the job again x or y.
every other setting seems to work like nesting start point and collars.
Intel(R) Core(TM) i5-6400 @ 2.70GHz 8.00 GB RAM
NVIDIA GeForce GTX 950
Windows 10 Professional 64-bit
http://www.trueform.ca
CS43 cnc
Clint Buechlein
Company Name: Thermwood Corp
Re: control nesting bug involving square off fall
Postby Clint Buechlein » Fri, Nov 10 2017, 2:51PM
Thomas,
Can you post an export from Control Nesting? Mine seems to be operating correctly so I'd like to see what settings you have different than I do.
Thomas strembitsky
Postby Thomas strembitsky » Fri, Nov 10 2017, 3:26PM
here you go
there is a cab file in the zip folder only way I could attach it. I can make a video if you need as well
control nesting export.zip
(114.56 KiB) Downloaded 19 times
CS43 cnc
Clint Buechlein
Postby Clint Buechlein » Fri, Nov 10 2017, 4:11PM
Thomas,
Got it sorry. Helps if I read your post better. Missed the part where you said go to Edit, rather than going into Settings, then Nesting Parameters. Sorry for wasting some of your time. We will get it listed and fixed.
Thomas strembitsky
Postby Thomas strembitsky » Fri, Nov 10 2017, 5:59PM
no problem. I just found out about doing it this way as its a bit of a time saver
CS43 cnc
