So i've been trying to figure out how to add some dividers for my door and drawer so when i close the door it stops on something and im not sure if they have an automatic option for that or if i would have to add a stretcher and manually do it.
~Nicholas
Dividers For Cabinet door and drawers
Nicholas Kiss
- Company Name: Clearcut
- Brad McIntosh
Re: Dividers For Cabinet door and drawers
Nicolas,
First off, your inquiry should have been in the "eCabinet Systems Software" forum section.
If you are looking for a "Drawer Stretcher" in a frame-less construction method, then...
In the "Shelf/Partion Editor" -
- Add a "Fixed Shelf".
- Select the "Fixed Shelf" you want to make a "Drawer Stretcher".
- Right-Click and select "Construction Settings". (This allows you to edit the parameters for the selected shelf.)
- Modify the "Back Inset" using the "Formula" [f(x)] button.
- Click the [Depth] button under "Cabinet Dimensions".
- Then insert "-" and "5" (or whatever width you want for the "Drawer Stretcher").
- Click [OK] to exit the "Formula Editor".
- Click [OK] to exit the "Construction Settings" for the selected shelf.
- Return to the main "Cabinet Editor" screen.
