How to make glass
Jeff Christenson
How to make glass
Postby Jeff Christenson » Sat, Feb 17 2018, 8:43AM
I need help making a glass panel for a shower wall. I have tried and tried and just cant get it. Any help would greatly appreciated.
Jeff C
Jeff Christenson
Jeff Christenson
Re: How to make glass
Postby Jeff Christenson » Mon, Feb 19 2018, 7:12AM
Nobody knows?
Jeff Christenson
Clint Buechlein
Company Name: Thermwood Corp
Postby Clint Buechlein » Mon, Feb 19 2018, 9:19AM
Jeff,
You will need to create a panel of the appropriate size in Cabinet Editor, use the Export Selection function, and then modifying the panel in Display Part Editor. You can then use the display part other times as well by scaling it in size.
Jeff Christenson
Postby Jeff Christenson » Mon, Feb 19 2018, 5:36PM
Thank you very much!
What settings should I set the colors on? ( red green and blue)
Jeff Christenson
Clint Buechlein
Postby Clint Buechlein » Tue, Feb 20 2018, 8:37AM
Jeff,
Check the box for Transmission On right below the color choices so you can see through it. Then you can play with the color values to get the color of glass you are looking for. 255 for each value will make it invisible, then you can take away some blue and green to get the color you want.
Jeff Christenson
Postby Jeff Christenson » Tue, Feb 20 2018, 9:17AM
Thank you Clint,
I did play around with it and got satisfactory results but it could be better. When I first got Ecabs it came with a manual and in that manual they explained how to make the glass, wish I still had that manual. It was several pages long, it took you through the entire process needed to create and edit cabinets in the part editor / display part editor plus all other areas of the program.
Jeff Christenson
Users browsing this forum: No registered users and 10 guests
