Thanks Tim/Clint, for the help with adding items. Exactly what I was looking for! I am not sure why I missed it in the "Help"
1. Can you be a little more descriptive about this?
So we have a cabinet with a door that has a 2 roll outs shelves. The bottom hinge has to get drilled at 120mm and the top at the standard 100mm the middle one can be right in the middle of the two because the middle roll out is there so we do a center offset of -57mm. If this is all put into construction defaults before placing the door it works (but usually doesn't happen). Now the cabinet is brought on site and the door gets damaged and we want to have a new one made up before we go back. Just to explain we bore our hinges on a mini press not the machine, so we don't have any easy way to tell where to bore. Is there a way to get those hinge locations without nesting the gables and figuring out center of hinge holes minus door gaps, partitions, yada yada? This works it just is a bit time consuming and to much room for human error.
So just wondering if there would be a way to add a line in this box.
- Capture.JPG (13.42 KiB) Viewed 9404 times
Hinge Location(s) 1- 100mm, 2- 743mm, 3- 1503mm
All referenced from top of door.
Does that explain it Clint?
BTW the Rolling eyes on the first post was my random posting!! Not Ecabinets! Awesome program! Loving the updates.
