Rolling Nest and Excell
Bill OConnell
Postby Bill OConnell » Fri, Jan 27 2006, 9:34AM
I was setting up to cut some simple rectangular panels and I thought I would give the Excel spreadsheet approach a try. I called up the example on Rolling Nest and followed it. However when I tried to open the sheet in Rolling Nest the program aborted. I tried it again with the same result. Any ideas?
GrussPanels.xls
Here is the Excel file
(13.5 KiB) Downloaded 131 times
Paul Ford
Postby Paul Ford » Fri, Jan 27 2006, 1:37PM
Hey Bill,
I tried this last week and had the same problem so i reinstalled V4.87 and it all worked fine after that.
Just wondering if the Thermwood guys might be able to change how it works so it works the sheet size off the name off the sheet stock? Rather than typing in the size off the board it is already saved in rolling nest isnt it?
Josh Meyer
Postby Josh Meyer » Fri, Jan 27 2006, 2:50PM
Bill,
I also had no problems loading and nesting your excel example list. I am running verison 4.87. If you aren't running that version you should download the update from http://www.thermwood.com.
