I have a frameless corner cabinet that I can't get the top of a shaker style door to adjust. It seem stuck at a few inches below the top of the cabinet.
I took a know good corner cabinet with approx the same specs and deleted the door and then tried to remake it using the cabinets original specs and I had the same problem, the door can't have the top adjusted.
I've attached the cabinet. It has the same door settings as the older cabinet I have used with success in an older kitchen. The top of the door does not adjust. Any help would be appreciated.
Can't get top of door in corner cab to get to top
- Attachments
- Corner.jpg (8.93 KiB) Viewed 4695 times
- Corner.hsf
- (274.02 KiB) Downloaded 349 times
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Re: Can't get top of door in corner cab to get to top
Hi Leo. I was able to get the door to adjust on my end by deleting the door and adding it back without making any changes to the settings that were applied to the cabinet that you posted.
- Attachments
- Leos Corner2.hsf
- (276.02 KiB) Downloaded 363 times
I rebooted my computer and tried again. Still having the problem.
The cabinet from my other build has the door built properly. As long as I don't change the door the cabinet is correct. As soon as I delete the door and try to rebuild it (with the same specs) it makes it short.
Not sure what's going on. Why you can get it to work and it still presents an issue for me. I've tried left and right hinges with the same results.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
