Double pass on thick material
Paul Ford
Postby Paul Ford » Mon, Jun 27 2005, 2:46PM
Hi all,
I have a job coming up in the next couple of days which has 30mm thick end panels. I was going to cut this with our 12mm cutter but I was just wondering if there is a way to do a double pass on all parts and still be able to onion skin the smaller parts.
Any advise on this would be very much appreciated.
Paul.
Brent East
Postby Brent East » Tue, Jun 28 2005, 9:27AM
Hi Paul,
Through the control nesting you are limited to two passes only. This can be set to do depth cuts for thick material or to use it as an onion skin but not both at the same time. If the parts are all very small you could change the waste board thickness to something just a little larger which would leave a skin on everything that you could come back and remove.
Thom Davies
Company Name: Dawn Group
Country: NEW ZEALAND
Postby Thom Davies » Wed, Jun 29 2005, 11:31PM
Hay Paul, Hows it going?
A another way could be in rolling nest settings change the double pass size which is in square mm set it to what your largst size panel is e.g a panel that is 700x1800x30mm MDF its square root is 1260000mm and in settings you can set what the frist pass will leave like it could be 15mm left for the second pass
Hope this helps
Cheers
Thom Davies
Dawn Group
Christchurch
Paul Ford
Postby Paul Ford » Thu, Jun 30 2005, 2:48PM
Hi all,
I thought that was what I was going to have to do. Looks like ill be cutting this job out in the next couple of days so I will see how it goes.
Thanks for your replies
Users browsing this forum: Google [Bot] and 3 guests
