MY FIRST DXF
Joe Soto
MY FIRST DXF
Postby Joe Soto » Mon, Jun 26 2006, 8:55AM
Hello everyone, I am trying to cut out a simple sign out of sign board, my problem is in the outline cut (no common close point) could someone look at it and tell me what I am doing wrong? It should be a square with a small border then the image 1in thick.
Joe Soto
Jason Susnjara
Postby Jason Susnjara » Mon, Jun 26 2006, 1:59PM
Hi Joe,
The reason the file called library signlayered.dxf gives you the error is because of the lines within the cutout of the person. If you look at the image below you will see that the red lines do not have closed entities. Your best bet would be to delete those red lines within the geometry. Just for a test, I deleted the red lines that you see below and then tried to nest the dxf file and it worked.
dxf file.JPG (92.4 KiB) Viewed 2284 times
Nick M Singer
Postby Nick M Singer » Tue, Jun 27 2006, 12:16AM
Can you use the same layer name more than once Jason?
Jason Susnjara
Postby Jason Susnjara » Tue, Jun 27 2006, 6:55AM
Nick,
You can only have 1 \"Outline\", but you can have multiple \"dados\", \"drills\", \"centertlines\", etc...
Nick M Singer
Postby Nick M Singer » Thu, Jul 06 2006, 6:36AM
Is that with the provision that one geometry does not run above the other?
Jason Susnjara
Postby Jason Susnjara » Thu, Jul 06 2006, 11:58AM
Nick,
I think there is a bug with using geometry on top of one another but it should work soon if it hasn't allready been fixed.
Bill Rutherford
Postby Bill Rutherford » Thu, Jul 06 2006, 3:11PM
Nick,
As far as I know the bug with recogonizing overlapping geometry regardless of the layer still exists. The answer is to offset the geomety by .001 between layers. Usually .001 will no cause a problem with parts.
Bill Rutherford
North Woods Manufacturing
Full service CNC Machining
and Edge Banding
http://www.northwoodsmanufacturing.com
Nick M Singer
Postby Nick M Singer » Thu, Jul 06 2006, 11:57PM
Thanks Jason and Bill. Iwill test it again. I suppose a 0.001 offset is no big deal, I am overjoyed when my staff achieve accuracies of 1mm
Users browsing this forum: No registered users and 11 guests
