Shelf edge moulding
Joe Murphy
Shelf edge moulding
Post by Joe Murphy »
Hi,
If I want to add a decorative edge to a shelf do I have to do that in the room editor?
Also, If I want a shelf to have a 1 1/2\" solid edge would that technically be a board stock option or an edgebanding option?
Joe
Joseph Murphy
President
Highland Woodworking
Nelsonville, NY
Mike Seisser
Company Name: NCB Inc.
Post by Mike Seisser »
You can do it in the room editor, but I usually do it in the cabinet editor, then associate the pieces to the cabinet(s) before saving.
Mike
Joe Stone
Post by Joe Stone »
Joe,
I don't think you will get what you want with the edgebanding features. You must bring it in as a display board and manually place it. Then associate it to the cabinet to be part of the design. Make your sure to add these after all other items are sized etc because they do not resize automatically with the rest of the cabinet.
Joe
Joe Stone
Precision Concept Cutting
http://www.pccmich.com
Mike Seisser
Hmmmmm, Joe Stone just gave me an idea. I wonder if one could manipulate stretchers to act as shelf bindings/nosings/trim?
Gonna go try it!
Mike
Nevermind, can't take em into Part Editor.....
Mike Bowers
Post by Mike Bowers »
Good idea :beer:
Michael S Murray
Post by Michael S Murray »
Hey Guys,
Could you not take a face frame wall cabinet, delete everything but the deck and the bottom rail, adjust to your needs and then take the bottom rail to the part editor? It would then at least be easy to resize. I do realize you would lose edge detail when you resize, but that would be better than starting from scratch everytime.
Mike Murray
mike@versatilecabinet.com
Mike Bowers
Another good idea. :beer: :beer:
Mark Taylor
Post by Mark Taylor »
Well I hadn't tried to add solid stock to a shelf yet, but I did assume that simply setting it up in the edgebanding would be the easiest...
I know we still have some issues with the edgebanding particularly out at the controller...so I have stayed away from using it. However it's relatively easy to set up a \"solid stock\" size up and adding it to shelving.
It was interesting to find out in the part's editor that if you cut into the \"edgebanding/solid stock\" it dissappeared and the shelf itself has the decorative edge. (it didn't matter how deep the solid stock was)
So - if you're simply adding solid stock, it's easy through edgebanding - however if you want a decorative edge a display board will serve you better.
Mark
solid stock shelf.jpg (65.19 KiB) Viewed 13614 times
Hey Joe, if you use 1 1/2\" edgebanding it will show on your cutlist correctly, the program just draws it flush with the shelf.
