Daylight Saving Time Issue
Dean Fehribach
Site Admin
Postby Dean Fehribach » Mon, Feb 12 2007, 10:09AM
The U.S. Energy Policy Act of 2005, passed by the U.S. Congress July, 2005, extended Daylight Saving Time (DST) in the U.S. by approximately four weeks. As a result, beginning in 2007, DST will start three weeks earlier on March 11, 2007, and end one week later on November 4, 2007, resulting in a new DST period that is four weeks longer than previously observed.
Thermwood machine controls running Windows XP and 2000 are affected by this act. Microsoft will be releasing a patch for Windows XP SP2 on February 13th via Automatic Updates. Microsoft will NOT be releasing a patch for Windows 2000 as its standard support has ended.
Download the Time Change Update for Windows XP SP2 Note: This update can only be installed on Windows XP with Service Pack 2. To find out if your system has Service Pack 2 installed, Click Start->Run->Type winver and click OK. If the dialog box that comes up says \"Service Pack 2\", then it's already installed. If it does not say that, then install Service Pack 2 before installing the Time Change Update.
Download Windows XP SP2 Installer Note: This link will allow downloading of Service Pack 2 for manual deployment to machines not connected to the Internet.
For more information, go to Microsoft's web site at:
http://support.microsoft.com/gp/cp_dst
Contact Thermwood for machine support at 800-221-3865 in the US. Do not contact Microsoft for Windows support on Thermwood machines.
Dean Fehribach
I.S. Mgr., Thermwood
Paul Ford
Postby Paul Ford » Tue, Feb 13 2007, 2:47AM
Hi Dean,
Thanks very much for that.
What do us 2000 users need to do?
Paul.
Dean Fehribach
Site Admin
Postby Dean Fehribach » Tue, Feb 13 2007, 1:54PM
Paul, as far as I know, this DST issue only affects these countries:
    United States
    Canada
    Mexico
    Brazil
    Uruguay
    Israel
    Egypt
    Sri Lanka
To answer about Windows 2000, time must be updated either manually or by modifying the registry. Registry modification can be found here (it's not for the faint of heart):
http://support.microsoft.com/kb/914387
Dean Fehribach
Paul Ford
Postby Paul Ford » Tue, Feb 13 2007, 2:00PM
Hi Dean,
Thanks very much for that. Ill just leave it be for now and see how I get on further down the track.
Paul.
Postby DanEpps » Tue, Feb 13 2007, 4:27PM
near the bottom of that KB article you will find a utility program you can download to change the timezone. It is named tzedit.exe and has instructions on how to use it so you don't have to manually fiddle with the registry.
Dean Fehribach
Site Admin
Postby Dean Fehribach » Tue, Mar 06 2007, 10:20AM
It should be noted that the operation of the Thermwood Supercontrol is not affected by the change in Daylight Saving Time; only the Timestamp of files that are created/modified is affected.
Dean Fehribach
Users browsing this forum: No registered users and 8 guests
