I can not take cnc out of e-stop, and i have tried everything i coul think of, i checked air pressure, tool lock out switch, ir module, restarting the computer, but nothing works , so i was hoping someone could help me.
thank you
cnc in e-stop
Solutions: E-Stop Mode
To,
Dear Mr. Nemanja Vujkovic,
If machine showing following errors : Air pressure low, axis 4/5 overlimit, Simence IR module in estop made. (These are the promlems probably may be cause)
As per my experience, definetly axis 4 or 5 is overlimit its permisible limit.
In machine OFF mode, you need to just rotate the axis 4 or 5 (which is overlimit or if not sure then just rotate both axis about 20-30 degree only) by hand to moving axis 4 or axis 5's Belt and just check the axis 4 and 5 should be out of switch button (Release from overlimit swich button)
Then remove the machine from estop mode. Definetly this will help you to solve your prob.
If still machine is in estop mode, then just mail your error message in estop mode then i like to suggest you more.
Regards
Sachin Gote
Email: sachin@wonderpackindustries.com
(Thermwood Sales & Service Engineer)
Wonderpack Industries P. Ltd.
India
Regards
Sachin Gote
India
Sachin Gote
Wonderpack Industires Pvt. Ltd
Nasik, India.
Nasik, India.
To,
Regards
Sachin Gote
India
Regards
Sachin Gote
India
Sachin Gote
Nasik, India.
Nasik, India.
