selecting an item
Clint Barden
selecting an item
Postby Clint Barden » Tue, Aug 21 2007, 6:58PM
How do you select a specific item?
I cannot select an item in the detail room that is covered by another item. Specifically a cabinet under a countertop or an appliance under a cabinet.
Thanks.
Postby DanEpps » Tue, Aug 21 2007, 7:18PM
Clint
Change to elevation view (double-click the wall) and you should be able to select the cabinet underneath the countertop.
Postby Kerry Fullington » Tue, Aug 21 2007, 7:45PM
Clint,
You can use the Page up and Page down keys on your keyboard to \"tip\" the room in Detail Room and allow you to select some cabinets under counter-tops.
Postby Rick Palechuk » Tue, Aug 21 2007, 8:01PM
I DIDN'T KNOW THAT!!! You need to hold the shift key while doing that. 8) :D
Postby Kerry Fullington » Tue, Aug 21 2007, 8:21PM
Rick,
You shouldn't have to hold the shift key for the page up and down.
Jean G Voyer
Postby Jean G Voyer » Tue, Aug 21 2007, 8:37PM
I didn't know that either but Kerry, Rick is right. It doesn't work if you don't whole the shift key. I tried with the caps lock but it doesn't work either.
You must have another secret that we don't know.
Jean-Gabriel Voyer
Janot Interiors Ltd
www.customcabinetscalgary.com
Al Navas
Postby Al Navas » Tue, Aug 21 2007, 8:54PM
No need to hold the SHIFT key, folks.
Are you using MACs, by any chance??? :roll:
GOTCHA, right?
Al
P.S.: I wonder if there is SOME setting in the eCabinets.ini file that accounts for these differences?
Postby Kerry Fullington » Tue, Aug 21 2007, 8:54PM
I have the special limited edition eCabinets that doesn't require you to hold the shift key.
Really I don't know. I don't have to.
Gene Kimmi
Postby Gene Kimmi » Tue, Aug 21 2007, 9:05PM
You can also use the show/hide feature to hide the countertops and other items. I use this a lot when I have to rework cabinets after I have put the counters on.
Gene Kimmi
Lenovo W540 windows 8.1 Pro
Samsung 256 SSD Drive
Clint Barden
Postby Clint Barden » Tue, Aug 21 2007, 9:28PM
Thanks for that tip. I don't need to hold the shift key, but holding it doesn't affect it either.
Nick M Singer
Postby Nick M Singer » Tue, Aug 21 2007, 10:37PM
Thanks for the tip (no pun intended) but it only tips the room in one direction. pity. Any way this brings me to a feature I would like to see added and perhaps others would too, it would help with the problem raised in this thread and in other respects as well. Could an object tree be included then items could be selected from the list and the properties edited there?
Postby Rick Palechuk » Tue, Aug 21 2007, 11:17PM
Your right Kerry. I was using the up/down on the num pad which require the shift key. I think a second article in the E-cab magazine is required. Kerry's tips and tricks.
Postby Rick Palechuk » Tue, Aug 21 2007, 11:25PM
Here's another tidbit I just found: In DR, ctrl click and drag a zoom window, then press home to view extents, then press end and it will bring you back to the zoom window.
Gene Kimmi
Postby Gene Kimmi » Tue, Aug 21 2007, 11:43PM
When you control, click, and draw your box to zoom, is there a fast way to return to the whole view in the detail room? I always click done, return to the main custom layout area and click reset view, then return to the detail room to continue. Just wondering if there is a faster way.
Gene Kimmi
Postby Rick Palechuk » Tue, Aug 21 2007, 11:48PM
Press the home key Gene.
Users browsing this forum: No registered users and 44 guests
