Frameless: stile or no stile?
Gene Davis
Postby Gene Davis » Tue, Jan 01 2008, 9:05AM
Right up front I'll ask forgiveness. Please excuse the use of Sketchup.
Here is a kitchen I am laying out to resolve cab types and sizes. The sink is centered under a window with 135 degree corners each side. A corner wallcab will be stuffed into each corner, the face runs are about 11 x 18.
Having not done one of these before, I wonder whether it might be good to place a center stile between doors, and use pocketscrews to fix it top and bottom. If we do that, we'll probably have to put the adj shelves in there before fixing the stile in place.
Or, should we just butt the doors, and leave our usual 3mm margin there as in any other paired door situation?
Unit 6 angled ground floor.jpg (97.98 KiB) Viewed 2193 times
135 wallcab center stile.jpg (63.68 KiB) Viewed 2193 times
Gene Davis
Re: Frameless: stile or no stile?
Postby Gene Davis » Tue, Jan 01 2008, 11:07AM
Here it is in eCabs, less its stile part.
corner wall 135.jpg (43.65 KiB) Viewed 2194 times
DaleKern
Postby DaleKern » Tue, Jan 01 2008, 11:13AM
Gene,
In my opinion I would skip the center stile - from the customer's perspective I would imagine having full access to a cabinet like that one would add more value than having the stile fill a tiny gap.
Happy New Year!
Dale
http://www.dalekern.com
Michael S Murray
Postby Michael S Murray » Wed, Jan 02 2008, 9:16AM
Gene,
I dont know your door sizes, but could you leave off the door edge profile and hinge that smaller door off the larger one, something like a corner suzan door?
Mike Murray
mike@versatilecabinet.com
Gene Davis
Postby Gene Davis » Thu, Jan 10 2008, 7:49PM
Mike, I took a close look today at some Blum bifold hinges I had. They are the ones we use for susan doors. I also looked at their specs in the manual.
I don't believe they will work for us in this config.
Here is the model of the cab showing machine-edge doors and a 3mm gap. Swinging open, there will be no interference. We'll prototype before using this, unless you want to, and you can report back.
135 BUTT.jpg (142.72 KiB) Viewed 1894 times
Return to “Customer Images”
