Creating a Circular Display Cube
Pat McFadden
Post by Pat McFadden »
I'm trying to create a circular display cube. It will become a frameless mirror. I tried taking a square, 1/4 inch thick cube into the Part Editor and cutting a circular geometry out of it, but how do I get it to keep the circle, not the rectangle with a circular cutout?
Pat
Mike Seisser
Company Name: NCB Inc.
Re: Creating a Circular Display Cube
Post by Mike Seisser »
Pat,
The most efficient way I know is to create 2 circles, use the larger circle to 'Create Part Using Closed Contour', then the smaller circle to 'Cut/Pocket Using Closed Contour'.
HTH
Mike
Gene Davis
Post by Gene Davis »
I am tearing my hair out trying to learn this.
I created a display cube 800mm x 800mm x 6mm thick. Took it into the part editor. Drew a large circle on it with the circle completely inside my square.
Selected the circle, then right clicked to be able to select "create part using closed contour." Selected that option.
Nothing happens. I take the part back into the cab editor and see the same big flat square panel I started with.
I can cut a circular hole through this cube, but cannot make a circular panel out of it.
Mike Seisser
Once you're in Part Editor click on the Contour Mode icon. Use the circle tool there to make an outline of a circle. Exit contour mode, Right click, choose "Create Part Using Closed Contour", select the circle, then click 'Next' at the bottom of the screen.
Sorry for the confusion, I kinda left out the Contour Mode step in my above post.
HTH
Mike
Also, to the OP, I misread your original request, thinking you wanted to make a mirror frame.
Pat McFadden
Thanks, Mike.
I was able to do it without creating 2 circles. Just drew one in Contour mode on top of my rectangular part, returned to part editor and clicked Create Part Using Closed Contour. I guess Create is the opposite of Cut as far as determining which element of the part is kept?
Cheers,
Pat
Mike Seisser
Pat McFadden wrote:Thanks, Mike.
Cheers,
Pat
Pat,
Yes, that's exactly it.
Again, I mis-read your original post when I suggested 2 circles, because I thought you were making a frame like this:
