Entertainment Center
Lamar Horton
Postby Lamar Horton » Thu, Mar 06 2008, 6:53PM
Here is the latest Entertainment Center. First time for pocket doors.
DaleKern
Re: Entertainment Center
Postby DaleKern » Fri, Mar 07 2008, 9:51AM
Lamar,
Nice job, I'm starting a simular project and your pictures will give me some encouragment to forge ahead. What hinges did you use for the bifold pocket doors - specifically the hinges between the bifold doors? Thanks in advance, and again nice work!
Dale
http://www.dalekern.com
Lamar Horton
Postby Lamar Horton » Fri, Mar 07 2008, 5:13PM
Thanks, I used piano hinges to fold the doors and a pocket door kit for them to slide back. I also had to use some blocks (the little blocks at the top of the opening) to keep the doors from buckling inside the cabinet while closed. I also used magnetic push catches to keep them closed. Because of the pulls, regular magnetic catches would have been better.
Bob l Spano
Postby Bob l Spano » Sat, Apr 12 2008, 5:34PM
Nice work man. hey, I saw your enterrainment center online & saw the ecab version. By the way, the cabinet looks great. I was wondering, how did you get the curve on the software? I really need to know how to do that. Can you help?
Thanks, bob
Lamar Horton
Postby Lamar Horton » Sun, Apr 13 2008, 9:18PM
Which EC was it. I have one with a double arch on top that I took the top rail into the part editor and cut the arches in.
Bob l Spano
Postby Bob l Spano » Sun, Apr 13 2008, 10:19PM
Any one that has a arch. I just need to know how to do that. Can you tell me how?
Lamar Horton wrote:Which EC was it. I have one with a double arch on top that I took the top rail into the part editor and cut the arches in.
Lamar Horton
Postby Lamar Horton » Tue, Apr 15 2008, 7:09PM
Bob, select the part you want to put the arch on. If it is a display panel, board or object you can take it directly to the Part Editor from either the Cabinet Editor or the Detail Room. If it is a part from a cabinet then you must take the cabinet to Cabinet Editor first, if you are not already there. Once you select the part and have taken it to the Part Editor choose the arc drawing tool to draw the arch. Switch back to the pointer tool then select the arch you have just drawn. It should turn red/orange. Right click then select Cut/Pocket Using Geometric Shapes, then select Cut through and that should do it.
Let me know if that works for you.
Joe Harkin
Re: Entertainment Center w/bifild doors
Postby Joe Harkin » Mon, Jul 21 2008, 10:32AM
Lamar the ent. ctr. with the "quad" doors (double-bifold) is something I need to do on my current project. I know I could build it the "old-fashioned" way, but not sure how to "build" it in eCab. How did you do it in eCab? Recent post in this thread refers to the eCab file for this job. Is it posted somewhere?
The problem for me seems to be that eCab only recognizes double doors and I have to put a center stile in the opening to make it take two sets of double doors.... what was your solution?
Great work overall, and great website - showcases your stuff very well.
Joe
Postby Rick Palechuk » Mon, Jul 21 2008, 2:28PM
Joe, you can use a partition with a front inset of all but 1/32". You can then place four doors with two partitions. HTH
Postby Rick Palechuk » Mon, Jul 21 2008, 2:34PM
Sorry, just one partition and then add double doors. :wink:
Std Upper Frameless.hsf
(176.02 KiB) Downloaded 215 times
Lamar Horton
Postby Lamar Horton » Mon, Jul 21 2008, 6:59PM
Yes Joe I used a center stile and added double doors. I set a 1/8 or 1/4 inset on the center stile so I could attach it to the door. This made the door gap between the sets of doors equal to the drawer gaps on the lower section.
Return to “Customer Images”
