eCab 5.2 batch issues
Steve Detina
Company Name: Silhouette Custom Cabinets
Postby Steve Detina » Mon, May 12 2008, 10:34AM
Hey guys,
First off I would like to say that I am really impressed with the new layout designer, makes things much easier. Thermwood and the programmers are doing a great job at providing us with a really good piece of software.
Since I have installed the new version I have been having problems batching jobs. When I batch a job I eCab will go through the entire process and then will generate a error and close. I will list the steps in which I create my jobs and batch them.
I have a standard directory where I keep all my cabinets.
For each job I pull the cabinets that I need resize them, modify them and then save them in a new directory.
From this directory I then pull all of the resized cabinets into the batch.
I save the batch job.
Send to CNC, and remit new value for material thickness.
Create TWD.
eCab go boom.
I have noticed that on some jobs that if I do not remit a value for the material thickness it creates the TWD file successfully.
I have attached a copy of the batch file.
Has anyone else had this problem.
error.doc
(82.5 KiB) Downloaded 79 times
10 - PR - LAYCOCK.esj
(3.52 MiB) Downloaded 82 times
Scott G Vaal
Re: eCab 5.2 batch issues
Postby Scott G Vaal » Tue, May 13 2008, 9:19AM
Steve,
I tried it on my PC and it worked (no crash). Does the twd file get created?? I have had one other person that I know of who gets a crash at the end of CNC from time to time but his will always create a good twd. I have not been able to reproduce it from his jobs either. Are you saving across a network?
Steve Detina
Postby Steve Detina » Tue, May 13 2008, 9:26AM
Scott;
Thanks for the reply. eCab does create a TWD and I have cut a couple of jobs only because I do not want to stop production. Are these files ok. I am not saving over a network, I am saving to my hard drive and then transferring the info on a memory stick to the machine. As for the PC, it is a gateway laptop that had vista but I removed it and reinstalled XP.
thanks in advance
Steve
Postby DanEpps » Tue, May 13 2008, 10:26AM
You might be running into a permissions issue with the file when you copy it to the second PC.
XP will sometimes block access to certain files copied from another system. Right-click on the file (in Windows Explorer) and select Properties. If there is a button labeled "Unblocl" (or something like that), click it and see if it works.
Scott G Vaal
Postby Scott G Vaal » Tue, May 13 2008, 10:31AM
Steve,
Do you typically have the job loaded that you run the CNC on? If so, would you run a test for me?
-> Start eCabs fresh.
-> Do NOT load the job!
-> Select the CNC Icon, choose this job and write it as you normally would.
...Does it crash?
Steve Detina
Postby Steve Detina » Tue, May 13 2008, 11:32AM
Scott;
You are a genius, I did as you asked and everything worked fine. I took it a step further and changed material thickness as well and it did not go boom. Is this just one of those things that I am going to have to live with or is it a hate to say it a bug.
thanks for your help
Steve
Users browsing this forum: No registered users and 17 guests
