DRAWER BOX ERROR
jerry johnson
DRAWER BOX ERROR
Postby jerry johnson » Fri, May 16 2008, 6:36PM
Could someone at Thermwood look at this file and tell me what is wrong? The mortise machines properly but the tennon is too thin. Thanks in advance!
apple .485 prifinished 230 box .5 bottom.hsf
(52.02 KiB) Downloaded 44 times
8)
Larry Epplin
Re: DRAWER BOX ERROR
Postby Larry Epplin » Mon, May 19 2008, 9:18AM
Hi Jerry. We have located the problem. Sorry for the inconvenience. We plan to have a patch available to fix the problem. I can not give a time when the patch will be available yet. We are working as diligently as possible. We appreciate your patience.
jerry johnson
Postby jerry johnson » Mon, May 19 2008, 3:45PM
Thanks, Larry.
David Hall
Postby David Hall » Mon, May 19 2008, 4:50PM
Same problem here.
According to the ecabs nest (and a sheet of drawer parts on its way to the dumpster)
It appears that when you change the tenons to greater than 50% thickness, the dados change in width, but most of the tenons remain at 50%.
50% thickness seems like it would work.
Dave
David Hall
Hall's Edge Inc.
eCabinets Machining Services
http://www.HallsEdge.com
Users browsing this forum: No registered users and 15 guests
