Hello everyone,
I spent most of my weekend trying to make a molding for a cabinet. After trying very hard... no success. Could someone give some tips on how to make a molding like that? I have a molding that I downloaded from somewhere, but I need in different sizes.
Thank you very much!
Molding
- Company Name: Two Mile
Molding
- Attachments
- Molding.hsf
- (120.02 KiB) Downloaded 312 times
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Designer Specialist
Re: Molding
Sergio...
obviously as you have figured out that would be a difficult accessory to make...but if the molding you have here works you can simply load it into the display part editor - add texture etc and then save it to a directory. At that point you can load it into the cabinet editor and resize it as needed.
Hope that helps
Mark
Hope that helps
Mark
Re: Molding
Mark,
Thank you very much for your help. Yes, I did realize the difficulty to create such.
Your suggestion is going to be well used. I will try to download some moldings from some other places.
Again thank you very much!
Sergio Fetter
Designer Specialist
Designer Specialist
