Small doors
Neal Reeves
Small doors
Post by Neal Reeves »
When I create a cabinet that has small door openings, the program tells me that my doors are too small and must be a certain minimum size and then deletes my doors and leaves my cabinet doorless. Even when I try to put a slab door on it, it gives me a message describing what the minimum size should be and then deletes the door. :wall: What do I do? Can I override this feature? :?: I have checked that I am getting the doors from an alternate source. How does this program know that my door company won't make my door the size I need?
Help please!!!
Neal Reeves
Country Cabinets, Inc.
Bonifay, FL
Re: Small doors
Can you post the cabinet Neal.
Paul Ford
Re: Small doors
Post by Paul Ford »
Neal,
When you first open eCabinets, click on "Define materials, costs and dimensions"> Select "Define Standard Dimensions". Then you can change the minimum door heights and widths and all should be good :)
