Triangular Cabinet & Line Drawing Editor
Rachelle DeShields
Postby Rachelle DeShields » Thu, Aug 21 2008, 8:55AM
I am trying to design a triangular corner cabinet but the "corner cabinet" won't let me set it the way I need it (with no left and right depths). Also, I've been having trouble with Line Drawing Editor since I installed build 2 of 5.2. It won't recognize or highlight some of the cabinets in an assembly to insert measurements. Anyone have any suggestions. Thanks :)
Todd Miller
Re: Triangular Cabinet & Line Drawing Editor
Postby Todd Miller » Thu, Aug 21 2008, 2:52PM
Rachelle DeShields wrote:I am trying to design a triangular corner cabinet but the "corner cabinet" won't let me set it the way I need it (with no left and right depths). Also, I've been having trouble with Line Drawing Editor since I installed build 2 of 5.2. It won't recognize or highlight some of the cabinets in an assembly to insert measurements. Anyone have any suggestions. Thanks :)
Rachelle,
First open a corner cabinet
Next, go into Construction settings and remove the left and right endpanels.
Then, set the Depth right Depth to .76 (If your material thickness is .75)
Finally, set the depth left depth to .76 (same as above)
NOTE: make sure you have the corner gap set to zero.
I have attached the file. HTH
I'll see what I can do about the LDE issue...
corner cab1.hsf
(138.02 KiB) Downloaded 92 times
Users browsing this forum: No registered users and 12 guests
