DWG or DXF
Gary Puckett
Company Name: The Woodworkery
DWG or DXF
Postby Gary Puckett » Fri, Oct 17 2008, 7:50AM
When you go to Kohler do you down load the DWG or DXF? To change it to a STL
Lamar Horton
Re: DWG or DXF
Postby Lamar Horton » Fri, Oct 17 2008, 8:39AM
I believe you need to have some additional software that can convert the files to stl. I'm not sure what software of were to get it either. Maybe to a google search for "dwg to stl" and see what hits you come up with.
Gary Puckett
Re: DWG or DXF
Postby Gary Puckett » Fri, Oct 17 2008, 8:46AM
Lamar I have the software to convert, I just forgot what file to down load.
I tried them both and got no results.
leigh mills
Re: DWG or DXF
Postby leigh mills » Fri, Oct 17 2008, 9:52AM
You can take DXF straight into eCabinets, the best place to do this is in the shape manager, not sure what you are trying to do. If you are wanting to take a 3D image into eCabinet the file type which I use is .skp, then I save it as a stl file which can be opened in the part editor.
Make sure you save it as different objects, for example if you are creating a chair save the legs seperate to the seat pad. This way you will be able to edit different colours in the part editor of ecab. Open one part change the colour then open the second part and change the colour.
If you need a source for your .skp files the best I can find is the google 3D warehouse, just go to google and type 3D warehouse.
This might not be what your after but hope it helps anyway.
Re: DWG or DXF
Postby Kerry Fullington » Fri, Oct 17 2008, 12:45PM
Gary,
Kohler offers a .dwg or .dxf of their 3D Models.
The easiest is to choose the 3D .dxf You can take this into Accutrans and convert it to .stl
Make sure you are getting the 3D model and not the 2D line drawings.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 47 guests
