Grass Zargen cuts on router
Michael S Murray
Postby Michael S Murray » Thu, Dec 11 2008, 3:14PM
Hello,
Is any one succesfully figured out how to use grass zargens in your library and be able to resize drawer material with machining? I currently have taken a drawer and eliminated all but the deck and back, set the insets accordingly and this will resize with the cabinets. This gives me the blank for the deck and back, but does not give me the groove in the deck or the dowel hole in the back, such a shame to have a machine but not be able to use it for basic functions like this. I do have quite a library built up, but would be willing to change it if some one has figured this out. Heres hoping for drawer part editing in the very near future, I feel it is right on top of the list for any one with a machine. :beer:
Mike Murray
mike@versatilecabinet.com
jerry johnson
Re: Grass Zargen cuts on router
Postby jerry johnson » Thu, Dec 11 2008, 5:56PM
Hi, Michael. I do not use the Grass system but I do use the Blum Tandem guides alot and the drawer boxes need holes and notches too. The way I got around the limitations in the drawer box editor was like this:
I create a drawer box that consists of only a left and right side made of a material I call "do not cut" and place these in the cabinets to get the holes bored in my partition and end panels for the slides. Then I created an upper cabinet that has all the joinery and materials I use in making drawer boxes. You can take the individual parts of this upper cabinet into the part editor to get the notches and holes needed for the rest of the hardware. To get a cut list I refer to the drawer box listing and enter them in a batch list using my special "upper cabinet drawer boxes." This is an extra step and I too hope that one day we will be able to take individual drawer box parts to the part editor but for now it works. 8)
Michael S Murray
Postby Michael S Murray » Thu, Dec 11 2008, 8:11PM
Hi Jerry, thanks for the suggestion,I have used your method when I need to make a scoop or tapered pullout.
Very time consuming to say the least. For my residential boxes I use the grass undermount that is very similar to the blum undermount and in fact uses the same drawer box. The way I whipped the notches was to make the deck slide in from the back, this eliminates the need for the notches, then we have a jig that locates the hole and we drill it with a hand drill at assembly.
Mike Murray
Users browsing this forum: No registered users and 48 guests
