column
Gary Puckett
Company Name: The Woodworkery
column
Postby Gary Puckett » Sun, Jan 18 2009, 8:33PM
Does anybody know where I can get a column like this in stl ?
Damon Nabors
Re: column
Postby Damon Nabors » Sun, Jan 18 2009, 10:05PM
Turn one in the parts editor with a display cube. Pretty easy.
Damon Nabors
Gary Puckett
Re: column
Postby Gary Puckett » Sun, Jan 18 2009, 10:10PM
Never done that so I wouldn't know where to start
Damon Nabors
Re: column
Postby Damon Nabors » Sun, Jan 18 2009, 10:23PM
Look at the video's for Part editor and it will explain how to use it.
First you will have to create a verticle tool in the shape of the column. Then create a round column out of a display cube and then pull up your tool and use the "Profile Edge" tool in the parts editor to run around the cylinder to create a turning.
Damon Nabors
Re: column
Postby Kerry Fullington » Mon, Jan 19 2009, 7:32AM
Gary,
Here is one I have used in the past. You should be able to Scale and re-texture it in the Display Part Editor.
column 12 84.zip
(367.82 KiB) Downloaded 385 times
Gary Puckett
Re: column
Postby Gary Puckett » Mon, Jan 19 2009, 8:59AM
Thanks Kerry that will work
Re: column
Postby DanEpps » Mon, Jan 19 2009, 9:37AM
Gary Puckett wrote:Thanks Kerry that will work
Ahhh...but you still don't know how to make the column for yourself. :wink:
Gary Puckett
Re: column
Postby Gary Puckett » Mon, Jan 19 2009, 10:29AM
Dan,
This is true but with having a lack of work, needed to get this drawing and bid out as soon as possible. There was no time to justify a learning curve. I am still going to put forth an effort to learn this, and I will still have some questions. I feel this is a process that I do need to acquire, but in this particular situation I felt the need to ask.
Re: column
Postby DanEpps » Mon, Jan 19 2009, 11:28AM
I feel that one should never try to learn something new while under the gun for a job.
Having said that, though, the procedure to create such a part only takes a couple of minutes at best and learning to create it doesn't take much longer.
The old "eCabinet Systems Made Easy" guide had a section on creating exactly such a corner post. Since it is not part of the software any more, you have to have it on your computer to use it.
Here is the section dealing with making a turned coner post (there are four images so it will take two posts):
Re: column
Final image...
Gary Puckett
Re: column
Postby Gary Puckett » Mon, Jan 19 2009, 2:04PM
Thanks Dan,
Once again you come through with step by step instructions, when everything smooths out ( with work) I will learn this.
At this point in time just trying to keep my head above water.
Return to “Customer 3D Files”
