Looking for a whachamacallit
Moderator: Jason Susnjara
Postby DanEpps » Mon, Mar 16 2009, 11:11AM
I'm looking for a piece of hardware but I don't know what it is called.
It is a metal "track" about 3/4 inch wide and is used to make height adjustments. It has an inverted stair step design and uses a spring-loaded bolt/latch to hold the desired position.
Any ideas on (a) what it is called and (b) where I can find it? I have searched for "height adjustment track" and similar but got no results.
The track looks somewhat like this:
Height Adj Track.jpg (11.07 KiB) Viewed 2214 times
Re: Looking for a whachamacallit
Postby George Davidson » Mon, Mar 16 2009, 5:10PM
Hi Dan here is something new on the Web.
http://www.sciencedaily.com/videos/2007 ... reated.htm
Ted Kittleson
Postby Ted Kittleson » Mon, Mar 16 2009, 5:21PM
Dan,
I think you are looking for a "pawl and ratchet mechanism".
Here is one for a Morris chair: http://www.hardwaretree.com/products.php?cat=149
and here is a bracket: http://www.leevalley.com/hardware/page. ... 50659&ap=1
I hope that helps, or at least narrows ypur search.
Ted
Postby DanEpps » Tue, Mar 17 2009, 6:39AM
Thanks Ted. Pawl and ratchet is probably exactly the term I'm looking for. The part you linked to won't work but it gives me something else to search on.
This is for a height adjustable tray that "climbs" a single standard.
Postby George Davidson » Tue, Mar 17 2009, 9:18AM
Would it be like on a drill press
The call that a gear rack
http://www.qtcgears.com/RFQ/Racks.htm
Postby DanEpps » Tue, Mar 17 2009, 10:34AM
No, it is more like a shelf. The track (rack) is dadoed into the standard and the tray (shelf) has the pawl.
A good analogy is an artist's easel where the center standard has an adjustable tray for holding paint, brushes, etc. You can raise it by simply pulling it up but you have to pull the "latch" to lower it.
Joe Redburn
Postby Joe Redburn » Fri, Apr 24 2009, 8:08PM
Rev a Shelf makes a plastic one the fits in the drawer bottom for adjustable partitions.
regards
Joe
Return to “Lounge”
