Toe Kick
John J. Desmond
Toe Kick
Post by John J. Desmond »
I am wondering if anyone has a great way of doing toe kicks? If I use ecabs only a front toe is on the cut list. It would be great if it gave a front and back toe. I keep sleepers on hand depending on the depth of the cabinet. I am trying to avoid adding a toe to every cabinet on the job. I have to save as an assembly after adding a toe and this is rather confusing when I am trying to remember where everything is, or I have to make a save file for each job in assemblies as well as cabinet. Any input into this :?:
John
jerry johnson
Re: Toe Kick
Post by jerry johnson »
John, just add a stretcher to the cabinet and it will resize with the cabinet. Then you can use your pre-made sleepers. 8)
BACK TOE.jpg (54.54 KiB) Viewed 9609 times
Re: Toe Kick
John, this is the re-sizable base I use.
Base.hsf
(112.02 KiB) Downloaded 910 times
Re: Toe Kick
Sorry John, misunderstood the question. If you follow Jerry's method that should work for you. You can also hilite the part and give it a user part name like Rear Toe kick. That will then show up on your cutlist.
