Base Cabinet Places off of Floor
Nat Wheatley
Postby Nat Wheatley » Sun, Jun 21 2009, 12:42PM
When I place this cabinet, it's ending up too far off of the floor. It will have leg levelers, so it should be 110mm of the floor, but it's ending up higher than that when placed. Anyone know what I'm doing wrong? Thanks.
2 Drawer File Cab - 608mm Deep - B.hsf
(812.02 KiB) Downloaded 67 times
Gary Puckett
Company Name: The Woodworkery
Re: Base Cabinet Places off of Floor
Postby Gary Puckett » Sun, Jun 21 2009, 12:47PM
Did you check the settings /preference tab. Then click Define Standard Dim. Check to see where your base cabinets are set at
Nat Wheatley
Postby Nat Wheatley » Sun, Jun 21 2009, 12:53PM
Just checked that, and I do have the setting for base cabinets at 0" off of floor. My other cabinets are placing ok, not sure what's going on with this one.
Paul Ellis
Postby Paul Ellis » Sun, Jun 21 2009, 2:38PM
Nat,
I think your levellers are screwed out too far! :joker:
No, seriously, I took your cabinet and changed the toe height to 0, saved the cabinet and opened it again, then changed
the height back to 110mm. It then placed at the correct height. (It originally installed at 220mm)
Hope this helps
Paul Ellis
"If it works, don't fix it"
Nat Wheatley
Postby Nat Wheatley » Sun, Jun 21 2009, 3:29PM
Thanks Paul,that did clear it up.
Nat
Jason Gooch
Postby Jason Gooch » Thu, Jun 25 2009, 12:03PM
I have experienced a similar problem. When I place cabinets in plan view they will end up the proper height from the floor. However in wall view, they'll be too high. Since I usually place things in wall view, I had to change my dimension to -100mm, so it would end up in the right place. Seems to be consistent, so I threw my hands up and kept moving.
www.appleboxwood.com
Users browsing this forum: No registered users and 19 guests
