Drawer Slides, Different Types Same Cabinet?
Nat Wheatley
Is it possible to specify a different slide for each drawer opening in a cabinet? I'm using a metal drawer system, and the hole patterns are the same for the member that mounts to the cabinet side, but the height changes with the different height drawers.
jerry johnson
Re: Drawer Slides, Different Types Same Cabinet?
Nat, you can designate a different drawer box, drawer front, drawer slide, or drawer/drawer slide placement for each opening. Select an opening then the drawer/hardware details and add the drawer. Select another opening and you can change any or all of the original choices you made for the first opening. Hope this helps.
Nat Wheatley
Thanks Jerry.
