Decorative Wood Products 3D Objects
HERE is a link to my downloads page where you will find links to the complete Osborne Wood Products and Hardware Resources collections of decorative wood products in .hsf format ready to use as display objects in eCabinet Systems Software. The .jpg preview files are also included. There are 371 different objects in the Osborne file and 250 in the Hardware resources.
These files have been taken into Accutrans 3D and the center point set so they rotate properly in eCabinets. They have been given a generic texture and appearance settings. They are ready to use in the Cabinet Editor and Custom Layout or they can be taken into the Display Part Editor and modified to suit your needs. They can be texture matched and scaled.
To use these files download the .zip files then right click on the zip file and choose extract all the files.
You can then cut or copy and past the new folder of files created into your eCabinets/import file. All of the objects can be accessed as Display Objects in eCabinets.
All of the files are labeled using their respective companies part numbers for easy identification.
Re: Decorative Wood Products 3D Objects
Below are some examples of the Osborne Wood Products Line
and the Hardware Resources Line
David Tuttle
Company Name: The Kings Woodwright
Post by David Tuttle »
I feel like a thief, I use a different company but much of the similar products. I'm just now trying to get the design editor to change some stuff, these programs you're referring to are all externally resourced I assume.
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
Kerry,
Thanks for posting these images, I know how much time it takes to convert .
Wow! Where do I send the sack of coolies? :beer: Thanks alot Kerry.
Jose Trillo
Company Name: TWC - Trillos Woodwork
Post by Jose Trillo »
A Zilion times THANK YOU it save my mind figuring out how to.
JT :D
I love wood don't you? :D
May Cui
Company Name: misani
Post by May Cui »
Kerry Fullington wrote:HERE is a link to my downloads page where you will find links to the complete Osborne Wood Products and Hardware Resources collections of decorative wood products in .hsf format ready to use as display objects in eCabinet Systems Software. The .jpg preview files are also included. There are 371 different objects in the Osborne file and 250 in the Hardware resources.
Hi Kerry,
the link HERE doesn't work now. can you fix it?
May
May,
I am sorry but those files are no longer available.
