Dual spindle
Discuss Thermwood 5-axis Machinery, Controller, and Software.
Moderators: Jason Susnjara, Clint Buechlein, Rich Kasten
Doug Oliver
Company Name: Ameri-Kart Corp.
Dual spindle
Postby Doug Oliver » Mon, Sep 07 2009, 8:12PM
I am required to use a G92 code in every program header. It makes things hard to bring Home, expecially after a bunch of 3D Rotary helix cuts on .200 HDPE. Thats the way I was trained. Now I have a 6" extentoin that i'm gonna have to use in a couple weeks, for a couple thousand parts and I dont know how! A crash is emminent unless I can get help!!! I hope Josh got some time on his bke, instead of being an Instructer to Knobs like me this summer. Wish him my best!!! Doug from Ameri-Kart can you hook me up with the dude that carves ice that i took the coarse with??????
Re: Dual spindle
Postby Ryan Hochgesang » Tue, Sep 08 2009, 10:46AM
Hi Doug,
The G92 is a fixture offset method which can be used to redefine a new origin for a given axis relative to HOME. When you have a dual spinde router, the origin for axis 5 is defined to the straight down position for tool # that has been called if the tool # is setup properly in tool management (actuator position 1 or 2), however the router does not rotate to that position until a B axis value is executed, then the spindle will move to position the router relative to the straight down or vertical position. If the tool # is setup as 3 axis use in tool management (actuator position 3 or 4 ), then axis 5 will position the tool to straight down position when calling the tool #. I hope this helps you understand how the offsets are used when setting up a 5 axis tool. Just let us know if you have additional questions or concerns. You can also email: program@thermwood.com for programming assistance.
Return to “Thermwood 5-Axis Machinery”
Users browsing this forum: No registered users and 0 guests
