Productive Edge Processing Machines
only from Thermwood and Fravol
Since 1963, Fravol
has been building high quality edgebanders and trimming machines for
woodworking. Today, Fravol offers a wide range of automatic, single
side edge processing machines along with a wide selection of options
designed for small to large shops. Fravol edge banders are heavy duty
machines engineered to perform in the most hostile environments. They
can process thin tape, 3mm PVC, HPL, aluminum and solid wood strips
up to 16mm thick, perfectly suited for all edge processing applications.
Fravol also offers semi-automatic edgebanders and trimming machines
for edging round or curved parts. Custom machines can be ordered to
meet exact requirements for manufacturing. And now, Fravol edge processing
machines are sold and serviced in the US by Thermwood, an established,
skilled organization known in the CNC router business for unsurpassed
customer service and support. If you are looking for an edge processing
machine with advanced technology, superior performance, high reliability
and long life that is installed, trained and serviced by an established
and respected service organization, give us a call.
Please Choose
a Type of Edge Bander |
The video above demonstrates a Fravol Edgebander (Model # Smart SX8). Thermwood imports the Fravol line of edgebanders from Italy. The corner rounding unit is a patent pending item that requires no separate set-up or adjustments to finish different profiles on panels. |
