To
check your machine's current software version:
press the "CTRL" and "V" keys simultaneously.
Software
Version 3.35
CadPath
CadPath
is used to convert a spline program into short (point
to point) line segments. The program no longer has to calculate
spline information "on the fly"; enabling it
to exceed the 200 IPM maximum spline feed rate and
can now also use length compensation.
Back
to top
Software
Version 3.39
Partial
NC Reset Warning
Allowing
a partial NC reset gives the 91000 SuperControl
great flexibility, however most of the time a
partial NC reset was not intended and an operator
may inadvertently cause the machine to perform
something not intended. This feature prompts
the operator and warns him of the situation.
If they indeed wanted a partial NC reset they
may accept it or if not they may cancel and perform
the proper full reset
Back
to top
Software
Version 3.45
Spline
Code
Spline
Code has been dramatically enhanced to allow for a
more predictable trajectory of motion when working
with rotary axes. The software now uses both the system
pivot distance and the active tool length to achieve
a true pivot distance value for spline calculations.
Back
to top
Software
Version 3.70
Probe
Scanning Auto-Save
The
software prompts for a file name before any type of
auto scanning is started and automatically saves at
the end of the scan. This helps eliminate the possibility
of losing a file because of operator error or power
outage after a scan is completed.
Back
to top
Software
Version 4.00
New
Operator Screen Layout
This
new layout utilizes high-resolution graphics for better
readability and appearance. Screen space has been enhanced
to display more valuable program information than before.
Back
to top
Software
Version 4.03
Graphic
Error Display
This
feature is used to help identify the cause of an E-Stop
error that may have occurred. A simple message outlining
the problem is displayed at the top of the screen along
with a graphic representation of the problem and its
location on the machine.
Back
to top
Software
Version 4.15
Service
Clock System
The
Service Clock assures the timely and necessary maintenance
of all serviceable parts on a machine. It tells the operator
via a message on the main menu button that service is
needed on a machine part. After pressing the button,
the Service Clock displays a picture of the part to be
maintained along with its location in red on the machine.
3-D
Rotary Helix Support
Added
support for 3-dimensional rotary helixes and
multiple rotary axes commands within all helical
arcs (2-D and 3-D).
Improved
File Overwrite Protection
This
protects against file loss due to accidental
file overwrite, erase, new part creation, etc.
Hand-Held
Block Stop
The
Hand-Held Programmer now allows the operator
to perform a Block Stop away from the control.
By pressing the "Jog" key on the
Hand-Held Programmer, a Block Stop is performed,
and program execution is halted.
Label
Quantity Increase
Maximum
label quantity has been increased from 99 to
1000.
Back
to top
Software
Version 4.25
Relative
Angle Movement (Axis 0)
Provides
an easy method to program a 5 axis machine with
rotary 4th and 5th axis to plunge on an angle or
compound angle without the use of trigonometry
to calculate the move. Axis zero (0) is designated
as the relative movement axis and when commanded
to move a given distance will move all the axes
necessary to make the router travel in the direction
it is pointing.
3-Point
Arc
The
3-Point Arc conversion has been improved for
working with rotary axis helical arcs. The
SuperControl now keeps the rotary axis in the
block of code after conversion, eliminating
the need to tab to the line and add them later.
Length
Compensation for Arcs
Length
Compensation now supports Arcs, 3-D Arcs and
all Helical Arcs.
Length
Compensation Display On/Off
The
upper left corner of the screen now displays
whether Length Compensation is On (active)
or Off (inactive).
Length
Compensation "On the Fly"
If
a program is stopped via Block Stop and a tool
table change is made to the currently active
tool, the SuperControl now automatically adjusts
to the new values upon a restart.
Tool
Holder/Turret Number Display
The
screen now displays the active Tool Holder
or Turret Number and enables operators to see
at a glance what tool should be in the router
spindle.
Dual
Table Pulse Wheel Programming
Operators
may now use the Pulse Wheel of the Hand-Held
Programmer directly to program on the second
table of a dual table machine.
Back
to top
Software
Version 4.39
AFL
Variables Increase
The
number of AFL variables has increased from 256 to 384.
New
Arc Creation Feature
Allows
arc centers to be defined in absolute while
programming.
Back
to top
Thermwood
99
Tool
Management System
The
Tool Management System was created to simplify
the management of the spindle types (actuators),
tool changers and tools on a machine. As the
systems on individual machines became more diversified,
tooling macros grew larger and more complex,
and executed slower. Tool Management solves this
problem by providing a central "fill in the
blank" type of program that allows the
configuration of actuators, tool changers and
the tools themselves. This can drastically
improve tool change times. Tool Management
especially benefits turret style tool change
machines, which now can rotate the turret,
reconfigure parameters for the new tool and
index simultaneously. Operators use the Tool
Setup screen to assign each tool to an actuator,
actuator position, tool changer and tool changer
position. The Thermwood Control automatically
enters the rest. The Tool Management System
allows tools 1-999 to be used on all machines.
In other words, any tool number can now be
assigned to any actuator. Also, more than one
tool number can be associated with the same
actuator. Examples: The Main Router on a standard
machine is not limited to tool 101. The Turret
will no longer be restricted to tools 141-156.
The fifty (50) tool changer will not be restricted
to tools 1-50.
3-D
Circle Macros for 5 Axis Machines
Macros
designed to automatically plunge into the middle
of the circle, move to twelve o-clock in a
straight line, complete a 360 degree circle,
move back to the center of the circle and then
retract out to the same location it was at
before performing the circle.
Quick
Shutdown
Perform
a quick system shutdown, safe and easily. Simply
press "alt-Q" simultaneously.
Pointer
Misalignment Message
This
message prompts the operator and warns of misalignment.
If a block stop is performed after start is
pushed and then the cursor is manually moved
from the current location and not put back
before the start, block step +, or block step
- are pushed again, it will warn of the misalignment.
World
Coordinate Program Values (G79)
This
new G-code is very similar to G90, except
that is always references machine Home regardless
of any active G92, G51, G54, G52L# or G53L#.
Part
Coordinate Set (G51)
This
redefines part zero relative to machine Home.
It doesn't perform any machine motions, and
cancels any previous G51 or active G92, G54,
G52L# or G53L#. Example: G51 X# Y#
Fixture
Offset (G52L#)
G52L#
references values stored in the fixture table
(which may contain up to 100 separate fixture
locations).
Fixture
Offset (G53L#)
The
G53L# redefines part zero relative to machine
Home. It performs an interpolated motion to
the values stored in the fixture table using
the last active feed rate, and cancels any
previous G53L# or any active G92, G51, G54,
G52L#.
Tool
Offset (G54)
This
G-code incrementally adjusts the current G92,
G51, G52L# or G53L# by the values stated. The
G54 values are defined by imagining the distance
and axis direction needed to get from the main
tool to the secondary tool. It does not perform
any machine motions.
Timer
Subprogram
Timer
Subprograms work by placing a subprogram at
the beginning of the program to mark the starting
point and then placing a subprogram at the
end marking the stopping point. The exact time
will be measured within one second of accuracy
and displayed on the SuperControl monitor.
Back
to top
Thermwood
2000
Part
Program Variable Color Display:
The
Thermwood part program display area now allows separate
colors to be set to individual Letter Codes (X, Y,
G, M, etc.) and Comment lines within the current
file loaded. This can make specific codes stand out and
easier to distinguish. Operator can set individual colors
from a list of 16. Colors do not display during run mode. (Some
colors may conflict with background colors)
Rapid
Traverse Teaching Capability:
The
SuperControl now allows "G00" Rapid
Traverse motions to be entered directly from
the Hand Held Programmer. To enter a move as
a rapid traverse use the normal line teach
function, but instead of just pressing the
enter key, press Shift + Speed + Enter and
the move will automatically be entered as a
rapid traverse move (G00).
Rapid
Traverse By-Pass Code:
M48
and M49. When M48 is executed it allows control
over G00 motions with the Feed Rate Override
knob. The M48 causes rapid traverse lines to
move at normal G01 acceleration rates but always
at top machine speed. The M49 or a HOME routine
sets this back to standard, where G00 moves
are not affected by the Feed Rate Override
and move at high acceleration rates. This feature
is very useful for proofing programs. Gives
you control over rapid moves via the Feed Rate
Override Knob without having to modify all
lines that are assigned to rapid traverse within
a part program.
Real
Time Tool Life Monitoring:
Tool
life is now more accurate than the previous
method. With the new system the SuperControl
will only reduce the life of the active tool
if machine motion is detected and the spindle
is on (if detectable).
Tool
Life Wear Factor:
This
feature allows the programmer to force the
tool life to diminish at a faster rate. This
is useful for programs that may use the same
tool to cut a multitude of different materials.
For example, a tool may last longer machining
oak vs. walnut and the tool life is set for
the max life for oak. So, if it is determined
that walnut wears the tool 1.5 times faster
then oak, then the following syntax can be
placed into the part program to adjust the
wear factor. Syntax: [WEARFAC 1.5].
Automatic
Tool Substitution Feature:
This
feature is designed for tool changing machines.
It allows the programmer to set a substitute
tool to be called automatically once the life
has expired on the main tool used. When a tool
is called the SuperControl checks if this tool's
life is expired, if it is it will automatically
call the next tool assigned as a substitute
for the called tool, as long as its life is
not expired as well. The only limit to the
number of substitute tools that can be set
is the capacity of the tool changer itself.
Tool
Management System (5-Axis):
Tool
Management System now implemented for 5-axis
machines.
Full
Label Scan Capability:
The
SuperControl now has the capability to scan
entire programs for labels. This allows extremely
large programs that contain labels to execute.
Vertical
Axis Clearance Motion Suppression:
It
is now possible to inhibit the "Z" axis
clearance motion when changing from one tool
to another on the same actuator. The system
automatically raises the 'Z" axis to the
full up, HOME position when you change from
one tool to another to assure clearance. In
some cases, you may not need this, for example
a dual spindle horizontal drill. When you change
from drilling with one end of the spindle to
other, it may not be necessary to perform the
clearance motion. It is now possible to inhibit
this clearance motion in these instances. Requires
the following syntax !No_Z_Up! to be
entered into the Description field of the tool
setup screen.
Back
to top
Software
Version 5.05
91000
SuperControl Version 5.05 Features |
- Fixture
Offset Temporary Adjustment Ability
- AFL
Current Programmed Feed rate Function allows
programmed modal feed rates to remain after
a tool change macro is executed.
- SuperControl
users can communicate with other users directly
from the control.
- Thermwood
Web store access from the 91000 SuperControl
- Ordering
of machine parts via part numbers or manual
description
- Radius
Compensation Temporary Adjustment Ability
- Axis
Oscillation Feature for extended cutter life
- Enhanced
Pointer Misalignment Function
- Programmer/operator
can get a snapshot of the current Feed rate
Override Value.
Click
Here for SuperControl 5.05 release information
Back
to top |
