Produce large-scale parts, tooling, and molds from a wide range of composite materials. Print and trim in a single, high-precision machine.
With their Thermwood LSAM MT, D-J Engineering produces complex tooling in weeks instead of months, making the process faster, predictable, and repeatable.
Dr. Byron Pipes and Dr. Eduardo Barocio explain how their Purdue collaboration with Thermwood LSAM is driving large-scale 3D printing and industrial composites innovation.
LSAM is engineered to dramatically accelerate production, reduce costs, and unlock new possibilities in large-part manufacturing.
Build massive parts and tools with print beds available up to 40 feet and beyond, enabling manufacturing on a scale previously thought impossible.
Go from a printed near-net-shape part to a final, trimmed, high-precision product on a single machine, streamlining your workflow.
Process virtually any composite thermoplastic, with temperatures up to 450°C to produce strong, durable, and reliable parts for demanding applications.
These are near net shape additive manufacturing systems that offer both print and trim on the same machine. They are configured with a fixed table, high walls, and a moving gantry or gantries, and can be fully enclosed to meet CE requirements.
Available Sizes: 10'x10', 10'x20', 10'x40', 15'x20', 15'x40'
The model numbers (1010, 1020, etc.) denote the table size in feet. While 40-foot lengths are common, even longer machines are possible.
This machine is configured with both a print and trim head on a single fixed gantry mounted over a 10'x12' moving table. Like the 1010, this system can both print and trim, but not at the same time. The open configuration cannot be built to meet CE requirements.
"Print Only" systems built around Thermwood's 40mm LSAM print head, offering highly capable machines at an attractive price point. These systems feature a single gantry, moving table configuration.
Available Table Sizes: 5'x5', 5'x10'
LSAM (pronounced L-Sam) represents the industry-leading technology for large scale 3D printing of thermoplastic polymers. It utilizes unique patented technology to produce the highest quality printed structures available.
LSAM uses the "Near Net Shape" approach to part production where the part is first printed at high speed slightly larger than needed, then trimmed to the final size and shape. This is the fastest, most efficient method of 3D printing large structures. With LSAM, both printing and trimming can be done on the same machine.
LSAM can process parts from virtually any thermoplastic composite material including high temperature materials that are ideal for molds and tooling. Its unique printing system produces parts that are solid, fully fused, vacuum tight and virtually void free, making it a full-fledged industrial additive manufacturing system intended for serious production.
LSAM prints a large bead at room temperature in a process which is an exercise in controlled cooling. A patented compression wheel totally fuses layers together, creating solid, virtually void-free structures that can sustain vacuum in an autoclave without add-on coatings.
LSAM machines are large, robust industrial structures built from fully annealed steel plate using slot-and-tab construction. This results in an order of magnitude higher strength and stiffness than typical machine construction. The entire machine is volumetrically compensated for superior accuracy.
The LSAM control provides unique functions to make the print process easier and more capable. It automatically synchronizes the melt pump output to machine speed for perfect bead dimensions, and orients the compression wheel to the direction of motion, eliminating the need for complex programming.
To address the lack of professional software for "Near Net Shape" printing, Thermwood developed a true CAD slicing software that works within Mastercam. It accepts geometry in every major CAD format and offers powerful, feature-rich programming capabilities.
