PLASTIC TRIMMING - PATTERNS - MOLDS - NON-FERROUS METALS
MULTIPURPOSE 90
Heavy-duty, high-speed trimming and pattern machining, available in single or dual moving aluminum tables
    Videos
    Model 90 5'x5' 5 Axis CNC Router Machining Medium Density Foam Tray
    Thermwood Model 90 Machining Bust in Low-Density Foam
    Thermwood Model 90 Modeling Foam and RenShape
    Thermwood Model 90 Dual Table 5'x5' CNC Router Cutting HD Foam
    Model 90 5'x5' 5 Axis CNC Router Machining Carbon Fiber Prosthetic Component
    Thermwood Model 90 Dual Table 5'x'5 Machining Honeycomb
    Thermwood Model 90 10'x5' 5 Axis with 10 Position Automatic Rotary Tool Changer
    Thermwood 5 Axis Model 90 Dual Table 5'x5' Machining Aluminum
    Thermwood Mastercam Solidworks Walkthrough Machining Aluminum Shield on 5 Axis Model 90
    Thermwood 5 Axis Model 90 Dual Table 5'x5' Aluminum Machining
    Model 90 5'x'5 5 Axis Plastic Trimming
    Machining a bar stool seat bottom on a Thermwood Model 90
    Model 90 5 Axis CNC Machining Pattern
    Request More Information
    MULTIPURPOSE 90
    Available Table Sizes:
    Single Table - 5'x'5, 5'x10', 10'x5'
    Dual Tables - 5'x5', 5'x10' and 5'x12'
    • 12 HP 24,000 RPM Router with a 4 Position Automatic Tool Changing System (Standard)
    • 21.5 HP 24,000 RPM Router with a 4 Position Bar Style Automatic Tool Changing System (Optional)
    • 16 HP 24,000 RPM Router with a 4 Position Bar Style Automatic Tool Changing System (Optional)
    • 1" Thick Solid Aluminum Vacuum Table (Standard)
    • 1/2" Thick Multi-Function Vacuum Table (Optional)
    • Extended Z Axis: 36" vertical (Optional)
    • Extended Z Axis: 48" vertical (Optional)
    • Extended Z Axis: 60" vertical (Optional)
    • Six Position Tool Bar Under Gantry (Optional)
    • Four Position Automatic Tool Changer - On Right Side Gantry Leg (Standard)
    • Ten Position Rotary Automatic Tool Changer (Optional)
    • Twelve Position Tool Bar (mounted to back of table) (Optional)
    • Automatic Tool Length Sensor (Optional)
    • Automatic Lubrication System (Optional
    • Gantry Lighting System (Optional)
    • Accu-Lube Mist Coolant System (Optional)
    • Machine Enclosure (Optional)
    • Impact Resistant Five Axis Head (Standard)
    • Continuous C Axis (Optional)
    • Intelligent Servo Drives Throughout
    • Thermwood SuperControl
    Request More Info Brochure Free eBook CNC Investment Calculator
    Machine Standard Features
      12 HP 24,000 RPM Router w/4 Position Bar Style Automatic Tool Changing System
      One (1) 12HP, 24,000 RPM variable speed router equipped with a four (4) position Automatic Tool Changing System. Includes four (4) ISO-30 tapered tool holders with four (4) collets, and preset tooling changing fixture. 3 positions will accept tooling up to 11.5 inch in overall length. Standard maximum tool size is 2” diameter. Standard
    • QCore SuperContro
      QCore SuperControl
      4 Position Automatic Tool Changer
      Four Position Automatic Tool Changer - Mounted in Gantry Leg. Includes four(4) ISO-30 tapered tool holders with four (4) collets. three positions will accept tooling up to 11.5 inch in overall length. Standard maximum tool size is 2" diameter. Standard
    • Machine Training
      Machine Training
    Machine Options
    • Six Position Bar Style Automatic Tool Changer
      6 Position Bar Style Automatic Tool Changer
      Six (6) position side load mounted tool bar is mounted to the top surface of the table.  This automatic tool change option allows tools up to 3.25 inches in diameter.  Optional
      Ten (10) Position Rotary Automatic Tool Changer. Includes ten (10) ISO-30 tool holders and collets and a pre-set tool holder fixture. (may instead include (10) HSK F63 tool holders/collets for an additional charge). Optional
      Provides an automatic method of measuring tool length and entering tool length offset numbers into the control.  This automatically compensates for the new tool length, eliminating the need to precisely locate the cutter bit.  It provides a highly accurate method of adjusting tool length for pocketing or profile edges. Optional
      Provides positive pressure, air/oil lubrication to the linear trackway bearings and the ball screws  This has two major benefits:  First, it eliminates the lubrication points which must be servided each shift.  Second, it provides positive pressure to the bearing, preventing contamination from entering the bearing.  This allows the machine to function in difficult, dusty or hostile environments. Optional
    • Remote Start/Stop Pedestal
      A remote pedestal with start/stop switches and a 30 foot cable. Optional
      • High quality bright quad row LED lights mounted in a weather resistant enclosure and designed for tough environments. The unit is mounted under the gantry for better examination of finished parts and illuminating the work envelope when programming at the machine. Optional
    • Vacuum Pump
      Universal Vacuum System is a unique method for holding panels to the table top for machining.  A sheet of particleboard or low density MDF is used as a work surface on the top fo the table.  The high flow pump vacuums through the work surface, holding the part to the table.  Pumps are available as 15HP (11kw).  Conventional vacuum also available. Optional
