High-Performance, Highly Reliable Siemens Drives (normally only on much more expensive machines)Full Function, High Performance CNC Control (compared to limited, bottom end controls)Designed using State of the Art ProEngineer CAD/CAM (assures best possible structure and performance)Weldments Fully Stress Relieved (eliminates stress warping and cracking down the road)Three-Dimensional Laser Compensated (machine is dead accurate everywhere – others can’t do this) |
(nesting at the control is easier and more productive)Free High-End Cabinet Design Software (eCabinet Systems is an industry leading software package)QuickCut - Select nested based products from a library at the machine control, resize and cut without the need for external computers or design software – the easiest way to make nested based products.Extensive Software Compatibility (control accepts output and can even combine files from a wide variety of design software including ProE, Catia, CabinetVision, eCabinet Systems, KCDw, AutoCAD DXF, etc.)Virtual Service (address any problem from configuration to programming by connecting the control directly to service – fast and really easy)Automatic Tool Management (manages tooling and tool life – not easy without this feature)Maintenance Tracking (manages lubrication and routine maintenance based on actual machine use)Error Reporting (graphically displays location of error and suggests remedy – with others finding and fixing is a nightmare)Maintenance Videos (on-screen videos guide you through adjustment and repair)Dynamic CAD Drawings (view and explode every machine assembly on the control screen for maintenance and part identification)Dynamic On Screen Manuals(view and search the machine manual right on the control screen) |
In-Depth Machine Training (formal class included with every machine)eCabinet Systems Software Training (included with every cabinet machine)Available Online Software Training (learn at your own pace with this ongoing program)Available Programming and Production Start-Up Assistance(get going quickly)Free eCabinet Systems Software Updates (no creeping annual software maintenance cost)Free Phone Support (as long as you own your machine)Virtual Service(instantly address virtually anything a service visit can – fast, without the service cost)Ongoing Control Updates(not available from others – you’re stuck with what you have)Free and Open Machine and Software Forums(get help from other users)Technical Support Visit Direct from the Factory (single source responsibility should you ever need it)Extensive Spare Parts Inventory with Overnight Shipping(should you ever need it) |
The bottom line: Thermwood systems install fast, start up quick, are easier to use and maintain, produce more and last longer.
