I have a huge problem printing line drawings. Every time I press the print icon the program closes. This means I have to restart the program for every drawing I want to print. This takes a very long time when you have 20 or so drawings to print.
So , I have to make my drawing, save the job, then press print, program closes, restart program, then go back to the line drawing and without making any changes print my drawing. Basically I have to restart the program for every print. Please help!
Jeff C
Program shuts down
Program shuts down
Jeff Christenson
Re: Program shuts down
Jeff,
In Settings/Preferences, is the box for Disable Crash Reporting checked? If so uncheck it and see if when the software crashes it gives you the option to send in a crash report. If it does, send in the report and post back the time and date you sent it in so we can match it up to your account. Hopefully it does give you the crash report and it can give us some more information.
Jeff,
When this happens, Instead of using the Print Icon,
Click On File and then Print or press CTRL+P to print your documents.
Always works for me.
The box for disable crash report is not checked. I did send one report.
I will try printing through the file menu.
Thank you for your help!
Jeff C
Jeff C
Jeff Christenson
