Removing toe kick and loosing geometry cuts
ian bacchet
Company Name: IB woodworking
Post by ian bacchet »
Can anyone explain to me why I loose all my geometry cuts with constraints as soon as I remove the toe kick in construction settings
Re: Removing toe kick and loosing geometry cuts
Post by Donald Thomson »
Good question. I have the same problems. If I have PE cuts on my end panels and decide to remove or add a toe kick, all my end panel PE cuts get deleted. I'm not sure why this happens. Maybe Clint can explain?
ian bacchet
looks like Clint cant explain lol
Clint Buechlein
Company Name: Thermwood Corp
Post by Clint Buechlein »
Sorry was on the road and usually just check forums for emergencies when I'm traveling.
When a toe kick is removed, the configuration of the ends are changed losing or adding data for boundary locations. The part editor cuts reference these locations so they must be removed to reset the part.
Not to say that something cannot be done about this, but that is how the software currently operates.
