i would like to find a species of wood that carves good sands smooth easily and is inexpensive. Right now i am going to try aromatic cedar. the wood needs to be as clear as possible. i will be needing the final sized blanks to be around 6" wide 3 inches thick and 12 " in length can be machined quickly with out splintering and with minimal checking and can be sourced locally here in Houston, Texas. I will be carving shapes like half of a soda bottle. they will probably be painted so color is not an issue.
thank you in advance,
Michael
what is the best and least expensive wood you have used for
Michael Kowalczyk, GM
Re: what is the best and least expensive wood you have used
Basswood domestic, Jelutong imported
Will
http://www.willmade.com
You might consider beach. I have never worked with it but I do see it a lot in carvings and turned pieces.
Here is a link that may help you with your decision.
http://www.wood-database.com/
Well, what did you finally end up using? how did the cedar work out?
Will
Hey Will haven't finished the 3D model yet. have Cedar but may switch to maple. will let you know soon but sorry guys no pics on this one. it is proprietary.
Michael,
Basswood is our choice and is great carving wood, no splinters, light and machines like butter. It is less $ than maple where we are. It is really soft though so handling is key after carving.
Hope your project goes well.
