control nesting 7.06 Bug
Thomas strembitsky
Post by Thomas strembitsky »
this one is interesting.
Load a job and add an off fall manually rectangular with a size that the parts will nest on to.
nest and look at the layout. then write to cnc and the parts on the sheet image are inflated. but if you check the cut paths they are correct.
code output is correct.PNG (9.08 KiB) Viewed 2693 times
NVIDIA GeForce GTX 950
http://www.trueform.ca
CS43 cnc
Tommy Wieler
Re: control nesting 7.06 Bug
Post by Tommy Wieler »
Seeing the same thing here.
Larry Epplin
Post by Larry Epplin »
We will get this resolved. Thanks for letting us know!
