I use a connestoga CRP-10 most of the time but cant seem to set it as tthe default. A flat slab door keeps becoming the default. What am I doing wrong?
Joseph Murphy
President
Highland Woodworking
Nelsonville, NY
When you select the door that you want to use, there should be a tab at the bottom of the screen in the center that says set as default. Make sure you click that \" set as default\" before you select ok.
The standard cabinets have the default door/drawer as slab, and you can not change the cabinets in the standard cabinet directory. However, you can load a standard cabinet and set the default door/drawer as crp-10 and then save the cabinet as a new seed cabinet. when you load this new seed cabinet, you will have the default door/drawer set as crp-10.
Just to clarify a little further for you, defaults belong to the cabinet instead of the software. This is what allows you to create libraries of seed cabinets with different construction methods and defaults such as materials, doors, drawers and hardware.
