Multiple Countertop Bug in BUild 3?
Joe Dusel
Post by Joe Dusel »
I think I have stumbled across yet another bug. It seems that if you place a few of the standard cabinets in an \"L\" shaped room, one on each wall, if you place countertops on both of them separately the software hangs when saving the file. I ran into this on a project I am doing then used a more simple layout to check it out.
By the way, I rolled back to Build 2 and this problem does not happen. Unfortunately all of the work that I did using Build 3 is not accessible using Build 2. I guess the files are not compatible. I would personally recommend NOT updating to Build 3 until all of these issues are resolved.
Lee Morris
Post by Lee Morris »
I have a similar problem. I have attached a job that I started in Build 2. I need to delete the 45\" countertop on the right. When I delete it and try to save the file, eCabinets hangs. I needed to make several changes to this job and then couldn't save it, so I started making changes one at a time to find the problem. Thats why there are no cabinets below the countertop.
Countertop problem.jpg (60.7 KiB) Viewed 6935 times
Lee
If the only tool you have is a hammer,
every problem looks like a nail.
Lee Morris
Here is the file.
SV Daily Drive Master Bath.esj
(6.24 MiB) Downloaded 678 times
Lee
Walker T Scott
Post by Walker T Scott »
Lee
Going in to the countertop editor more than once on a job will cause eCabinets to hang on the save, there is a work around, just simply take a countertop to the part editor and then return you don’t have to do any thing to the countertop and it should save fine.
Last edited by Walker T Scott on Fri, May 11 2007, 6:10AM, edited 1 time in total.
Walker T Scott
Lee
Hers a work around for now.
1.) load SV Daily Drive Master Bath
2.) go to detail room
3.) select show/hide from the mouse tier
4.) uncheck hide countertops and press ok
5.) select the countertop to the right
6.) select delete from the mouse tier
7.) then save it
This should work if you have any more problems pleas let us know.
Walker
Rob Perry
Location: Qualicum Beach, Beautiful British Columbia, Canada
Post by Rob Perry »
I Just started doing a revision for a Customer thats coming by tommorow morning and I'm Just finding out I'm having the same problem. When I try to add a second Countertop It Won't Save. It Just hangs. File Attached,
I am going to try do get it done with display cubes.
Rob
Rob Perry
Post by Rob Perry »
Since I Made my last post I read on another thread that taking the newly added countertop to the part editor before saving will allow it to save without hanging.. It Worked !!! I did Not make any changes to the Countertop while in part Editor ...
Rob
