Does anyone have problem with hole patterns, or is it just me?
They never seem to work perfectly. They are either not deep enough, or they are just slightly misplaced.
This goes for hinge and slide patterns!
Some of the \"supplied\" hole patterns are NOT deep enough. You may have to change them then save the new pattern. Also, if your partition/end is not flush with the faceframe, the holes will not be deep enough as the depth starts at the edge of the faceframe openning.
