Toe Kick
Joe Ford
Toe Kick
Post by Joe Ford »
I build my cabinets with the toe kick attached to the front side of the end panel instead of between them. However, I can't seem to find out how to make this happen in ecabinet systems. I would appreciate any suggestions anyone might have.
This is the way I do it
Michael Yeargain
Post by Michael Yeargain »
Your full dado depth should the same thickness as the end panel. George is using a 3/4\" generic material therefore the depth of the full dado will be 3/4\"
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Joe Ford
Post by Joe Ford »
Thanks guys... I have been searching for a way to do that for a really long time.
Joe,
You don't have to use the full dado trick any more. Go to the Toe Kick tab in Construction Settings and add a negative left and right inset to the kick that is equal to the thickness of your end panel materials. This will lengthen the kick.
