Right End not nesting properly
Jeff Sallows
Post by Jeff Sallows »
I just noticed today that a job we ran last friday ended up not doing any machining on the right ends, it strictly cut out a rectangular piece the size the gable was to be? This only happened on my upper cabinets, not my lowers, does anyone know what could be up?? I have tried just nest the one cabinet, but no go. I will attach the .hsf, we need a fix asap because this is really holding up production!
Micro.hsf
Here is the micro cabinet thats not machining
(364.02 KiB) Downloaded 713 times
Joe Soto
Post by Joe Soto »
Jeff, I don't know why but remove the edgebanding from the bottom of the right end, then it will nest correctly.
Mark Hesketh
Company Name: Paris Kitchens
Post by Mark Hesketh »
checked it out and no matter what I do, I can't get the right gable to show any of the cuts on it. It only shows up as an outline in the nest. I have exhausted all my tricks trying to make it work and still no luck.
Unfortunately, most of the guys that might be able to fix this will all be on vacation today (4th of July). Hopefully one of the non-American forum users can figure it out if you can't wait.
Sorry I wasn't much help.
Jeff,
I think they are aware of this problem and working on it.
Here is another thread talking about this.
Maybe Chris might know more.
Jeff Sallows
Thanks everyone for there input , I forgot that it was July 4th, well I'm going to try to remove the edgebanding like joe said and see what happens. Thanks again!
Michael RA Greschuk
Post by Michael RA Greschuk »
Hi Jeff, I went into global settings and reentered your global parameters did a no change on material clicked ok and resaved seemed to work hope it helps Mike
Michael RA Greschuk
Hi again Jeff, I just noticed looking at your cab after the fact that the dado was not cut on the left end of your deck.Back to the drawing board I guess :?
Michael RA Greschuk
Hi Jeff, I changed the percentage of the blind dado tenon setting to 51% after noticing the thickness of your material seems to work maybe :?
Michael RA Greschuk
Forgot the file
Walker T Scott
Post by Walker T Scott »
Jeff
This will be fixed in the next patch.
Walker
Chris Robinson
Company Name: Chris Robinson
Post by Chris Robinson »
Jeff, that happened on my last job except that only the base right ends were affected. Good to hear there's a fix coming down the pike. It's a real PITA to fix manually! I'm just glad I didn't use blind dado construction on that one!
Thanks Walker for the update.
Chris
