A new Door/Drawer Editor Bug in Build 4?
Al Navas
Post by Al Navas »
I was changing some settings in the Door/Drawer Editor while creating some images for an earlier post, and I ran into the problem I show in the image below.
How I got this result:
1. Started with a Standard Base Cabinet
2. Went into the Door/Drawer Editor
3. Selected both existing doors, to make changes to the Insets and Overlaps
4. Changed the Door Inset value first, and clicked OK - no problem
5. Changed the overlap values for the existing doors ===>> BAM!!! Doors reacted badly, as shown in the image below.
I can reproduce this, so it does seem to be a bug. This does NOT happen when removing the existing doors and adding new ones - it happens ONLY if I change the settings of the existing cabinet doors.
Al
P.S.: I think this is all Dan's fault :lol:
Al
http://sandal-woodsblog.com
Michael Yeargain
Post by Michael Yeargain »
Let's blame it on Dan today.
This has been an issue for some time. At least with all three of my computers. If I select the doors and front, make changes they do weird things, such as the image above. One of these days it will get fixed.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Al Navas
Post by Al Navas »
Mike,
I guess I did not report anything new, then.
Luckily, the fix is easy enough: Simply delete the existing door(s), even after they acted up, and place new ones in the Door/Drawer Editor; THEN everything is OK with the doors.
I seem to recall you did have some problems with the toe kick inverting sometimes. I have yet to see that one on my system.
Al
Re:
Huh? What? I don't remember doing anything. :shock:
Michael Yeargain
Well if you don't remember then; it is definitely your fault Dan. Now we see that this is the Ole \"I don't remember trick...\" :lol:
32Gigs DDR4
Corsair RM650
Leo Graywacz
Re:
Post by Leo Graywacz »
Al Navas wrote: I seem to recall you did have some problems with the toe kick inverting sometimes. I have yet to see that one on my system.
Al
I believe that was my problem. I have since rebuilt all of my seed cabinets in version V5.1.3. Now that I am using V5.1.4 things seemed to have improved. I tried to get the cabinets to flip their toekicks but couldn't make them do it. But all the cabinets I built in version 5.1.1 are slow, very slow. When I open them in the Cab Editor they take minutes to get where I can edit them. The same cabinet, reseeded works in seconds.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Al Navas
Post by Al Navas »
Leo Graywacz wrote:...Now that I am using V5.1.4 things seemed to have improved. I tried to get the cabinets to flip their toekicks but couldn't make them do it. But all the cabinets I built in version 5.1.1 are slow, very slow. When I open them in the Cab Editor they take minutes to get where I can edit them. The same cabinet, reseeded works in seconds.
Great, Leo! I agree that Build 4 is pretty solid so far.
Are you able to reproduce THIS problem with existing doors? Mike reported he still gets similar errors when working on existing doors. Maybe Mike and I are the only ones having this problem.
Al
Leo Graywacz
I have had the problem you're talking about but mine seems to manifest itself in a different way and it seems to be more random and not reproducible. When I resize a cabinet the doors don't always resize properly and stay the same size. Actually one door seems to do OK but the second one seems to not get sized right and moves off center. The program no longer sees this door and it cannot be selected. It is also part of the cabinet and will be move to any area with this defect. The only way I have found to remove it is start over, total failure in other words. I have not experienced this in build 4, but I haven't done a lot in build 4 as it is so new.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Michael Yeargain
Build 4 has improved this feature greatly. I have tried a few cabinets so far and have not had any problems changing doors or stock yet.
I did notice in a few of my seed cabinets there are inset carvings that I didn't place their. They are in the center of the cabinet and are random. Most of my cabinet don't have this but a few do. Can't tell you how they got their as I don't have a router and don't need the carvings their.
From my understanding; when a file is saved now, the software looks for anomalies and deletes them, rendering the cabinets to their assumed glory.
32Gigs DDR4
Corsair RM650
Al Navas
Re:
Post by Al Navas »
Michael Yeargain wrote:... From my understanding; when a file is saved now, the software looks for anomalies and deletes them, rendering the cabinets to their assumed glory.
I wonder what makes you think this is so, Mike. Is it something you might be able to share? If this is the case, should the program have deleted the error I show above with the doors? Would this error be considered an anomaly?
More importantly, I also wonder what it is that the program might consider an anomaly, and how one might avoid it. Would an anomaly be anything that is not in the sub-directories of the eCabinet Systems folder?
Al
All that happens is that the data is updated to the latest specification when the file is regenerated and saved. If you do not regen it by either changing something or going into construction settings, nothing is updated.
Michael Yeargain
I am refering to a conversation I had with one of the programers a couple of weeks ago. What exactly the software looks for? I have no clue. It is just what I said. As I understand it.
I had a problem with a few of my cabinets having carvings in them. And once I placed the cabinet into the room. They some how had babies. Yea they multiplied. How I don't know. One job I sent to Thermwood had over 4000 carvings in it, after I deleated all the cabinets! Go figure.
As far as the word \"anomolies\" I chose, it is just a word I used. Of course I paraphrased what was told to me...
32Gigs DDR4
Corsair RM650
Al Navas
Post by Al Navas »
Mike,
I really, REALLY wanted it to be something that would sense and then remove errors like the one I show in the first post of this thread. I had NO idea what was happening, until I was able to reproduce it.
Al
Michael Yeargain
Like I said Al,
I really don't think it will catch anything new, but I was just trying to explain with my own words what was said to me...
32Gigs DDR4
Corsair RM650
Michael S Murray
Post by Michael S Murray »
Hey Mike, can I price those carvings to you? I been looking for some high production jobs for the router!!!!!
\"(had a problem with a few of my cabinets having carvings in them. And once I placed the cabinet into the room. They some how had babies. Yea they multiplied. How I don't know. One job I sent to Thermwood had over 4000 carvings in it, after I deleated all the cabinets! Go figure.)\"
Mike Murray
mike@versatilecabinet.com
