Gene Davis
Post
by Gene Davis » Thu, Sep 27 2007, 12:22PM
I designed my basecabs at 23.75 depth so ends and decks would \"stack\" two-across on a 48-wide sheet.
Now I see they don't. What's up here?
Why not stack.jpg (87.15 KiB) Viewed 3450 times
Justin Melhiser
Post
by Justin Melhiser » Thu, Sep 27 2007, 12:28PM
Gene
What do you have set for the collar in the ecabinets nest?
Thank You
Justin
Gene Davis
Post
by Gene Davis » Thu, Sep 27 2007, 12:37PM
I just took the default of 1/2\". This is being shipped out via email as a production sharing job.
Justin Melhiser
Post
by Justin Melhiser » Thu, Sep 27 2007, 12:38PM
Gene
Do you get the same nest with the 1/2\" taken out?
Mark Hesketh
Posts: 366 Joined: Fri, Aug 25 2006, 9:12AM
Company Name: Paris Kitchens
Post
by Mark Hesketh » Thu, Sep 27 2007, 1:18PM
keep in mind that the machine wants to run your outline tool all the way around each part. so the part generally starts a bit inside the sheet, and has the diamater of the outline tool plus a bit between each part. also depends on whether you have it set to nest horizontally or vertically.
