Strange new popup
Peter Walsh
Strange new popup
Post by Peter Walsh »
My eCab seems to be running fine, but I today I clicked on the \"Communications\" link on the top menu and checked to see if my software needed updating. I got the attached popup (see jpg). I tried again and it checked the update which was OK. I tried it again and repeatedly got the popup. I've never had this before. Haven't changed anything related to my internet connections but did add a new, really sweet LCD monitor yesterday with no other changes inside or to the box.
Wierd.
regards,
eCab popup.jpg (18.1 KiB) Viewed 3092 times
Michael Yeargain
Post by Michael Yeargain »
Peter,
Do you have dial-up?
If you have DSL or Cable then,
go to START>CONTROL PANEL>INTERNET OPTIONS>CONNECTIONS, then select LAN settings at the bottom right of the dialog, Then see if there is a check beside the \"Automaticlly Detect Settings. If not check the box and click OK. This should do it.
If this doesn't help there could be a problem with the internet connection itself or it has been blocked by a spyware program.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Peter Walsh
Michael,
It did indeed fix the problem. I have no idea why this got unchecked. Another unsolved mystery in the adventures of software.
many thanks,
Michael Yeargain
You bet... :lol:
32Gigs DDR4
Corsair RM650
