After I load a cabinet from a library and make changes to the size of the cabinet box when I try and save the new cabinet, the size reverts back to the original size.
Can anyone help?
Cabinet size will not change
Tim
After you make the changes to your cabinet size, if you move the mouse over the ccabinet parts, a box should pop up and tell you the size of that part. You can check the different parts, the top, deck, left and right ends, to see if your cabinet adjusted. If it does not post or email the cabinet to me with what sizes you are trying to change it to.
