Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
MarcoKnjaschewitsch
Posts: 73 Joined: Fri, Jan 26 2007, 1:44AM
Post
by MarcoKnjaschewitsch » Fri, Mar 07 2008, 11:50AM
Ok So i have profile modeler doing what i want in the right area(Thankyou Thermwood!!!!) Now i do not want to do a perimiter cut but my locater pins do not pop up and i forgot the manual way to raise them... Is this also going to be acurate enough???? i need it to use my locater pins as we cut panel beforehand to size so i need to just put my V-Grooves in..
Pete Riddle
Post
by Pete Riddle » Fri, Mar 07 2008, 4:37PM
Marco,
I think I understand what you are asking here.
If you write the program from Profile Modeler, you will have to add a couple of lines of code at the begining of your program.
M61L8 (popup pin output on. IF OP8 is the correct OP. Check your schematics)
M00 (press start to continue)
M62L8 (Popup pin output off)
I hope this helps,
Pete Riddle
Post
by Pete Riddle » Fri, Mar 07 2008, 4:38PM
MarcoKnjaschewitsch wrote: also does it need to be a double pass on my profile edge to run?????
I'm sorry, I don't know what you are asking here.
MarcoKnjaschewitsch
Post
by MarcoKnjaschewitsch » Fri, Mar 07 2008, 7:29PM
Well when you run the v-groove can it be done in one run down the board or will it always do a finishing pass??
