Backing up
Terry Davis
Company Name: Penn Laminates
Backing up
Post by Terry Davis »
We bought an External harddrive for backing up Ecabs and other files, what files on the Thermwood (CS45-510) should be backed up?
David Egnoski
Re: Backing up
Post by David Egnoski »
It's best to use "Backup My Files" on the eCabinet Systems "File" menu. It should backup everything you need to be concerned about.
Dave Egnoski
Richmond Cabinet & Millwork
Re: Backing up
Files on the Super Control are not part of the eCabinets backups and must be backed-up separately.
David Egnoski
Re: Backing up
Guess I should read the question more carefully next time!
Dave Egnoski
Terry Davis
Re: Backing up
Yes that is what I mean Dan, what, where and how do I back up the files on the Supercontrol.
Re: Backing up
One of the Thermwood folks needs to ring in on this. I don't have a CNC so I don't know what files should be backed-up.
FredHirsch
Re: Backing up
Post by FredHirsch »
Here is what we do on the control. I think this list came from THM
c:\macros\*
c:\offset.tab
c:\rolling nest\*
c:\system\toolman.thm
c:\spasswrd.thm
c:\tpasswrd.thm
d:\*
Fred
Fred Hirsch
Dan Voges
Re: Backing up
Post by Dan Voges »
This topic has already been covered in the THERMWOOD forum. Here is a list of the files that should be backed up for your machine:
o C:\Rolling Nest\machine. <----- (Control Nesting - SETTINGS)
o C:\Rolling Nest\tools.thm <----- (Control Nesting - TOOLS)
o C:\Rolling Nest\material.mdb <----- (Control Nesting - Material Database)
o C:\system\toolman.thm <----- (THM Tool Manager Settings, Tool Changer positions)
o C:\offset.tab <----- (Fixture offsets for G52L#)
o C:\MACROS <----- (Contains M999, most commonly altered)
o D:\DATA <----- (Contains all CNC files and folders)
Optional, but highly recommended if you have updated your machine:
o C:\system\ cmark.bin <----- (Contains any C-Marker Offsets)
o C:\system\ Thmfmt.bin <----- (Contains machine properties)
o C:\system\ THMMSU.BIN <----- (Contains machine properties)
o C:\ Msufmt \ “Machine number”.MSU [ie: C:\msufmt\CS45510.msu] <----- (Contains machine properties that can be viewed)
The spassword.thm and the tpassword.thm are necessary if you have changed the service passwords from their original defaults. If these files accidentally get missed in the backup, the machine will default back to its factory settings password of either "thm" or "toolman".
