Looking for Info on a CNC Machine
JohnLashuay
Post by JohnLashuay »
I am looking to purchase a CNC and I was wondering which direction to go.
This is what I am looking for:
We mainly work with closets, so I need a cnc to drill 2 full line bores on each panel. Also with those panels, we use a rail hung system and I notch the top back of each panel.
We use 4 x 8 sheets, but sometime can get 5 x 9's.
We use a rafix system from Hafele.
Most all of our work is shelves and panels with some slab drawer faces and doors.
We make our own drawer boxes and order out dovetail. Our drawer boxes that we make are datoed, biscuited, glued and stapled. Can a cnc route out the dato and also the groves for the biscuits?
Given these requirement, what are my options, and what would be best?
Thanks in advance for any input!!
John
http://www.rylexonline.com
Thermwood CS 43
Justin Melhiser
Re: Looking for Info on a CNC Machine
Post by Justin Melhiser »
John
I passed on your information to the account manager for New York. A dealer in your area or the account manager should contact you today.
JohnLashuay
Thanks Justin,
I will look forward to his call.
John
Thermwood CS 43
Gary Urlacher
Post by Gary Urlacher »
I recommend a CS 45 5-10 machine. Depending on the number of gables you would need to produce in a day would
play a big part in the addition of a drill bank for the machine. Just using the head to drill is very fast. The machine moves at 1600IPM
on these moves so when you blink, it has moved on and done a hole.
The intergration with ecabinets is great and your drawer boxes would not be an issue. With the assembly of the drawers you
do now, I suggest you use the blind dato method for your drawers. This would eliminate the need for biscuits and that additional
assembly step. The machine will handle a 5 x 10 sheet so you are covered there.
The notch in you cabinet back is possible but be carful when you design your cabinet back to try to eliminate a flip operation.
Flip opps on Thermwood machines are simple but it is one more step that we try to avoid when possible.
Good luck in your hunting.
JohnLashuay
Gary,
Thanks for you response! This research has been an incredible one. There is so much info to look into. I did meet with a Glenn Suss, who is the rep out here, and it was impressive!
The more research I do, the more I find that Thermwood is the best fit for us. Each software and each CNC have been weeding themselves out for a number of reasons.
I am looking forward to moving ahead at the right time, hopefully soon.
John
Thermwood CS 43
jerry johnson
Post by jerry johnson »
John, the Thermwood machine will do all you need. Something to consider is you do not need to bore full rows of holes. The ecabients software will put holes where you need them for drawer slides, adjustable shelves, rafix fasteners, hinge plates or anything else you need. Also, as Gary pointed out, you can use blind mortise and tennon construction on your drawer boxes and eliminate the need for biscuts. I build all my drawers this way. Have fun in your research! 8)
SAMPLE CLOSET.jpg (78.76 KiB) Viewed 10653 times
Michael Kowalczyk
Post by Michael Kowalczyk »
sorry wrong thread
Michael Kowalczyk, GM
